Blue pearl
Hey all,
I have a 96 HX that I cannot seem to get running right. Fuel lines have been replaced, carbs rebuilt with oem mikuni and new gaskets. I dont have my spec sheet handy iirc pop off in both carbs was ~49psi. Needle and seats held 20+ psi over time. The fuel pump seems to flow fuel well into the carbs, although there are air bubbles time to time. Stock jetting sizes. Replaced rotary valve + cover and set timing. Trimmed back plug wires. New Spark plugs. Compression 135/140. Always 93 octane fresh fuel. Fuel system also holds 3ish psi. To my knowledge, there are no aftermarket parts on the ski
Performance of the ski:
Excessive cranking to start in or out of the water. It idles well and seems to have decent response from idle to half throttle. If I cruise at half throttle and then open full, the power comes on very slowly. Once at full RPM, it seems ok. It also struggles to drag me through the water and has a hard time taking off. Every other HX I have ridden seems to want to jump out of the water, including my wife’s 95’.
Could this be a jetting issue? Even tho I am running factory sizes? Could a bad coil cause this performance? My friend also mentioned to me to check if the crankcase is holding pressure. If that is a possibility, any suggestions on how to test that?
Overall, the ski just feels “weak”
Help will be much appreciated.
