Still shifter trouble
Something doesn't sound the same. My forward cable is on the left looking at the jet outlet, and the one on the right pushes the reverse gate down. Neither have adjustments. The gate also does not click on the forward fully you have to puch it up a 1/2 inch to make it click. I assume the water flowing does this in the water.
I'll look to see whather there are some adjustments in the engine compartment. You really have to strong arm the thing into forward and then it just lightly falls into reverse.
So I have had some intersting days in the last 7 or so. I tried to get things rolling for a family reunion on the lake and ended up bringing the tools with me just in case, still having the shifter problem, and will take up Snipe's suggestion of looking for bent linkages in the controls.
Ended up breaking the supporting mechanism and make-shifting a repair from aluminum channel. Works ok, but will still have to find root problem. Shifter is loose when gates disconnected, and gates seem to move freely, so I think it's the combination of when gates are attached the friction of "something" kicks in and makes forward shifting tough. Oddly enough, if I shift with one engine shut off, it's no problem, so I have a work around for now. I think that might be a clue as well, that the water pressure against (either) gate is enough to add the friction to shifting.
So anyway, another neat finding: (this is meant as no endorsement, only my experience):
Starboard carb was gunked badly. I changed internal carb filter in the city. Worked well. Port carb seemed ok for the moment. On the lake the Port carb was obviously just as gunked and I used Seafoam as directed to clear the gunk. I knew it was a toss up, but thought I would try it first. Dumped into fuel line and drew about three (8 ") lines of Seafoam into carb. Then stalled it so it wouldn't start. Then I left it two hours and came back. Wouldn't fire at all. So I gave up and tore it down.
Looked everywhere for gunk and varnish. NONE! The Port carb was clean as a whistle. Now remember, I tore the Starb carb down and found a ton of varnish in both filters and behind the diaphram. The second was clean. Neither carb had ever been opened (in 11 years). So I slapped it back on and still had the same problem. Maybe the Seafoam had fouled the plugs? R&R'd the plugs with new ones, and wham! Started right up.
OK, so...I don't want to make a statement like Seafoam did the trick or that this was proof, because that carb could have been clear to begin with..but then why the same restriction problem in the beginning? And would these carbs not have looked similar for contamination after 11 years? Interesting experiment. I would try Seafoam again before peeling down the carb, but would carry extra plugs as they get fouled something awful. Easier that carb R&clean. (also Seafoam works excellent for a cleaning agent for most anything on the engine).
Any further suggestions on the shifter would be appreciated, I can't get at the underside for a few days, only at the shifter.
Cheers! Don
