stinger520
I am having trouble with an engine seizing on my 1995 seadoo SPI. I bought the ski a few weeks ago and the first time I took it out the engine seized. The flywheel was locked solid and would not turn. I was able to break free the flywheel and start the ski again.
I brought the ski to a mechanic and he couldn't figure out the problem without seeing the ski seized. The ski appears to be getting plenty of oil (I actually fouled the plugs a week later from it running too rich). The engine was NOT hydrolocked. The engine has good balanced compression. I thought it was actually fine and had ridden it pretty hard a few days, but it recently seized up again putting for a long period of time around the canals. (Maybe more likely at RPMs?) It also only appears to seize after the engine is stoped (doesn't lock up while running), only if you stop the engine and go to restart it (one case actually only locked up after leaving it for awhile).
The mechanic thought if it was the bearing near the flywheel on the driveshaft there would be some flex in the shaft itself. Anyone have any idea what might be the cause or what I should take apart to try and find the problem (it is currently in a seized position). Again the flywheel is rock solid (I could probably break it free again, but want to try and trouble shoot it while locked)
Thank you for your help.
