Seats removed pics..
south texas
Hi guys,
I have a strange request: does anyone have pics of an older speedster or challenger with the seats removed? I'd like to have a better idea before I pull mine out.
Thanks in advance.
Hey South_Texas,
Sorry I missed the post... I was trying to check to see if the models were the same!
SeadooBOB helped me out with his post :-)
The seats aren't too hard actually to get out. Just some patience and good balance!
I used a 10mm socket on a 3/8" extender to a 3/8" ratchet.
Open your engine hood and lift out the storage tray. There are 6 bolts for the back seat rest. You may have to move some loom & hoses out of the way to see them. Those are the easy ones. Just when putting the back seat back in, thread all 6 before cranking them down or the holes won't line up again properly.
For the bottom of the seat there's 4 bolts, again I think I used the same socket. These are touch as you have to pretty much bend in half around the opening of the engine compat. unless you have arms like a monkey and can reach right in there. There's 2 on each side and of those, the front ones are pretty much as far forward was you can get!
I hope that helps. If I can help it I never want to take out the bottom seat cushion again, my gut was killin me from bedning and reaching so far in. I used a small pillow on top of the engine/floor just to gice my head a bit of support when leaning in too.
quick response!!
Guys, thanks for the fast responses. I've read the procedure for removing, but actually seeing the boat without the seats makes it much easier to visualize. Thanks again for your help!
