Seat removal 2009 is255
gpetry
Newb question here.. Just bought a 2009 RXT is255 and need to have the seat recovered. Is there a recomended way to take off the seat prop arms - The forward screws are a little easier to get to but they seem to be spinning without loosing - do I need to remove the storage compartment to get to nuts inside or should I use the rear screws that are a lot harder to get to?
Newb question here.. Just bought a 2009 RXT is255 and need to have the seat recovered. Is there a recommended way to take off the seat prop arms - The forward screws are a little easier to get to but they seem to be spinning without loosing - do I need to remove the storage compartment to get to nuts inside or should I use the rear screws that are a lot harder to get to?
I am a bit confused, I also own a 200- RXT-X. The seat comes off of the ski via a latch at the rear of the cushion. It is a two piece seat. Remove the back one and then you can get to the latch of the front one.
You are right. My 2008 RXP-X the seat just lifts off. On the suspension skis, the seat is actually hinged at the front and lifts up and props like a hood on a car. Two screws for the hinge was easy. I have the seat off, was just wondering if I did it right and if its going to be a major pain to get back on. I did the rear screw on the port side and the front on the starboard.
Ahhh, I got ya.. I missed the iS part....
