Seadoo XP LTD 2 stroke lubricant?
bullman
Hi,
I am new to PWC and have purchased the ski above, I know I have to flush out the water after use but someone reccomended using a lubricant after each use can anybody advise?
Thanks
I use wd-40 and spray everything down. I also use silicon spray on the cables and all the electrical inside the engine also. The only time you need to flush it is if you run in salt water. In fresh water it isn't necessary. You need to add you model and year to your avatar for future problems...Use mine as an example.
Karl
