Seadoo temperatures when running
cvdoc2001
What should the exhaust and intake temperatures be showing under normal operation on a Seadoo LRV with a 951 rotax engine? Also, What would you consider a high temperature?
Thanks....
Intake?? Whatever the air temp is.
Exhaust temps can be as high as 1200 Deg F. But if you push them that high for too long... you will melt the piston.
I don't think your LRV shows either of those temps on the display.
Normal running temp is around 190~200 Deg F. (in the water jacket)
If I'm reading your question wrong... just let me know... and I'll try to get you the right answer. :cheers:
