seadoo rxdi 03 crank ? please help
jetti12
why crankshaft balance iron is not completely 180 degrees compared to another balance iron. You will notice the difference when comparing the balance of the iron edge to the side of the block. the air pump piston cut off and I noticed that at the same time.
the pistons move at very different times also at the top and bottom dead spots which is correct.
once the engine itself stopped quickly with sound, apparently because of the air piston when cutting
