RFI motors have 5 sensors that provide information to the fuel injection system. 1) throttle position sensor. 2) water temp. 3) air temp. 4) air pressure. 5) crankshaft position sensor. If one of these sensors malfunctions the watercraft will be put into limp mode and will be rev-limited to get the operator back to land.
RFI fuel systems. The fuel system consists of .1) the fuel pump. 2) the fuel pressure regulator. 3) the fuel filter. 4) the fuel level sensor. 5) the fuel injector. Every thing listed here except the fuel injector is located in the fuel pump assembly which is located in the fuel tank. Fuel pressure should be tested while the watercraft is under a load, due to the fact that the fuel pressure can change drastically from just checking it at idle. The correct fuel pressure should be 56-60 psi.
With the information listed above there are many variables to consider when In most cases an engine that runs poorly or does not run at all may be the result of a sensor malfunction, poor fuel pressure, clogged fuel filter, bad throttle position sensor or a throttle position sensor that is not adjusted properly, Incorrect spark plus and last but not least a BATTERY That does not have proper voltage while cranking over the motor. Insure BR8ES plugs are gapped .021. (.020-.024).
Most of these sensors can be checked by ohms testing and the use of the factory repair manual which is highly recommended when performing an engine swap. Any authorized dealer of the brand watercraft has the ability to do complete diagnostics to find electrical and fuel related issues that might be occurring that the customer can not solve them selves. BUDS. But cannot read Fuel or Mechanical malfuntion.
The fuel pump setup for RFI (RotaxFuelInjection) is GM based. That is partially true, but not entirely. The pump itself is a Bosch pump that crosses to a BMW Z3, but it very similar to the pump used for a 95 Chevy Beretta. It is also the same pump used in a 97-04 Jeep Grand Cherokee. The Part number you want for the fuel pump is 69223. The fuel socks are as follows: the internal sock (inside the canister) is also for a Jeep Grand Cherokee, 97-04, Airtex part number FS220. The external sock (at the bottom of the fuel module) is for a Saturn 1.9L, Airtex #FS242. The fuel pressure regulator is for a Chrysler, returnless style fuel system. I am trying to cross the exact application, but I am betting one for a Jeep is right, but it is also very similar to the ones used in all 2g Dodge Neons (2000-2005) and PT Cruisers (all models). All of those models run at a spec'd 58psi.
One of Mine started losing prime because the rubber gasket that holds the bottom of the pump was rotted. I undo all the nuts and remove the pump as a unit from the tank, then dissasemble. I determined A mixture of one part Toluol (tolulene) to four parts gas is ideal for rejuvinating the pump. I put a short line onto the out nipple of the pump and put the pump in a bowl (1/3 full) and apply 12v and lightly tap on it, then after it begins running, if pukes the orange crap out and then runs better. After a few minutes I had a great working pump! I used a rag on a stiff wire to clean the tank. I used the mixture to clean the pump fuel sock and the filter. I found alot of debris in the fuel rail when I used the mixture. WARNING: Toluol has a very low flash point (very combustible). Use caution in an open area. I have found
othere cleaners NOT to be effective. Toluol can be bought at hardware and paint
suppliers for around $16.00 a gallon. I also advise you consult your service manual.
