Linwoodinmaine
I bought this 97 GTS jet ski as a project, as far as I know it had no problems starting I charge the battery and the jet ski started up fine after replacing the exhaust manifold it would not start. For awhile I would not get two beeps when key was inserted but after cleaning post and key i did end up getting two beeps again. I get 2 beeps when key is inserted but will not turn over when I press the start button. After watching videos online in talking to my local sea-doo dealer I bought and replaced the solenoid with no avail. I did take the electrical box apart and tested the ohm ratings with the lanyard on and off the post, off the post was an open circuit and with it on the post ohms were 0. I also tested the starter by crossing the solenoid and the engine did turn over but would not start. I also looked at both fuses in the electrical box and both tested fine, a lot of the videos showed three fuses but only saw two in mine I don't know if there is another fuse for the MPEM but didn’t see any others and at his point I am getting two beeps. What is so frustrating is it would start up and run perfectly before I replaced the exhaust manifold. Years ago I used to work on 2 stroke dirt bikes but this is a whole new breed for me didn't know if anyone had any suggestions or answers thanks Linwood
