I have read a number of these forums but I am not sure it has identified my issue(I may have a few). I had someone with a lot of experience with sea-doos try to get my 1996 GTX Bombardier started (Rotex 717). We bought it knowing it was not running at the time and probably has not started in 4-5 years. He rebuilt the carbs and replaced most of the hoses but it seems that gas is not feeding to the carb. Could bad gas be the cause? I think we added gas to start to try to dilute anything bad. We would dump the fuel filter up front and it would not refill.
Is there a decent manual that identifies just the fuel system and lines? The ones I have reviewed did not have great images associated with them.
We spray an engine starter fluid and it would catch then die. (Tried wd40 without the same result). Spark plugs look good. The one thing I did notice was the pump located at top of the oil tank is a 'T". One of the t connections is a gas/oil lines to under the propultion system. The other is open. I would think a vacuum would need to be created but I am not sure.
I am not all that solid with this type of stuff but I am willing to learn as I did rebuilt the carb on the 2000 Sea Doo that we owned which resolved the issue.
