I recently replaced my impellers and wear rings as part of the rebuild process. The wear rings were a really tight fit, in fact the motors wouldn't even turn over until I oiled the impellers with WD-40 and cranked the starter 30-40 times. This cut shavings out of the plastic wear rings. I do not think the thrust bearing was pinched since the pump spun freely in between the parts where it contacted the wear ring.
The problem is that my Starboard pump makes an intermittant screeching sound. The sound got better throughout the 30 minute test run. Everything runs fine, RPMs are good, speed is 50-55mph. When I start the engine on the trailer, it does not make the sound. I was actually able to record the screeching sound which you can find here:
https://www.youtube.com/watch?v=yczGH4yvqng
The sound starts about 1-2 seconds after I hit the throttle in the video. You can see what my hands are doing with the throttles for most of the video.
I assume I need to take the pump apart and make sure everything is ok in there.
