Your jet pump pulls water in to cool your engine. So if you ran in shallow water or beach it or jump waves in shallow water sand will be pulled into your pump then goes into your head and water jackets, it will go out the head into the head pipe. This is why you should stay away from shallow areas and always flush your machine after each ride. And if you ever beach your machine, before you start it get behind the machine and using the grab bar, push the machine away from you and then pull it back a couple times, that will clear out any sand or rocks out of your pump. Also the head pipe plugs are known for corroding away, make sure you have both of the plugs on the bottom fixed/welded. I have only had 1 pipe out of all the 787s we have bought be in good shape, they have either been welded already or they have holes in them.
