Rxt valve train question/opinion
Minton33
So I recently bought two “blown up” 2005 rxt 215 for 500$ bucks, with a double trailer. I pulled both the engines and the flywheel bolts have backed out of both and the bolts had wedged themselves in there preventing it from turning over. Of course there’s metal shavings everywhere.
im thinking I’m going to disassemble the engines, see what if anything is damaged. Probably go ahead and do all new bearings and rings, new flywheel and stator and make sure everything is cleaned out good.
i have read about these having issues with the exhaust valves so was wanting to go ahead and replace them. The place I work is a sbt dealer and From sbt can get 6 exhaust valves for 267$, full head rebuild for 359$ or a full dressed head exchange for 399$. With those prices it would almost be a no brainer to just get a new head with new cam and all. But not sure on if the sbt stuff would be worth using.
so my question is would it be worth getting 2 sbt heads for 399 apiece or what are the other options to get away from these stock exhaust valves
I've had very good luck with sbt valves. I normally just replace all the valves in the stock heads and they run perfectly for a very long time. Have your local machine shop lap them in and vacuum test the head which they will do cheaply.
I wonder if that would actually be cheaper than replacing the head by the time I find a machine shop and have them mess with it. There’s only a 132$ difference in replacing the whole head or just the exhaust valves. Not to mention all the valves would be new plug new seals, ect.
Just kind of concerned on the quality of the sbt head
I did my 2005 RXT about 2 years ago for the same reason.
If you end up having to replace timing chain with guides, rebuild 2 oil pumps, replace bearings, bolts, gaskets, a damaged piston, rings, buy the special tools needed and rebuild it yourself, you will be in it for about $3k each plus head work.
If the machines were used in salt water you may find out the prop shaft is severely corroded (pitted) under the carbon seal making it almost impossible to reassemble when the O-rings roll. Grease makes this worse. Light oil was better.
A new single piston may be a different weight than the 2 old ones which can cause a balance issue.
Most people selling used parts do not know what they have so if you go this way make sure you buy from someone who accepts returns. Returned 2 cams and 1 piston on E-bay.
What was the reasoning for replacing the timing chain and guides on yours? In theory looking at the oil path the oil filter should have caught everything before it went through the engine although both of the pumps are scored. According to the po they were running fine and just shut off. So far I’ve only pulled the stator covers off and oil pumps and I see no damage to block or timing chains or anything. Only the flywheel and stator, and pumps
I replaced it because it had close to 200 hours and the engine was out.
I already spent about $3K so I decided to change anything (cost within reason) which can go bad while it is apart. OEM TC and guides was about $130.
Pump scoring on these machines is expected as hours go up. All my bearings were perfect and there were no signs of metal debris anywhere..
Why was the stator and flywheel damaged?
The bolts backed out of the flywheel and shredded the stator.
