I have a 2000 rx di that I bought and it has turned into a nightmare. It would not run after I put all the hoses back on I finally got it to start. It did not run well so I put a gauge in line with the fuel line and found that it would not hold 107 psi. So I put a new HFP-342DI in and cleaned the rave valves. I started it up on the hose and it started hard but did after a few tries fuel pressure was around the 107 range. but it still had a hard time to rev up. I let it idle for about 10min and would see if it would rev up after awhile. It still had a hard time and will still bog out if you held it to it but if u let off it would go back to idle. So I put in the lake to try and it was worse it would still idle and you could just briefly give any throttle pressure was still 105-107. I tried this for about 10 min still made no difference. So I am looking for some help to go next? Compression is good (135-140), voltage is 13.5,fuel pressure 105-107psi, and no codes. Maybe TPS? Help please
Adam
Adam
