chaseschrecker
On my 650 rotax motor I'm hearing my rotary valve seals are leaking by the heavy oil from exhuast is it possible it's just the seal on the rotary valve itself leaking or is it most likely the two seals on the crank? Or do I just have to check them all? Any help would be appreciated! If I pull the crank to change those seals the crank would have to be remachined and all I can't just change them is that correct?
