Ok this has been driving me crazy!!
I have a 96 HX with the 718. I was having trouble getting it to start (has been sitting for a year) . Anyway I got it to start, took it to the lake and it ran great for about 20 minutes then it just died. Then it would not start.
I charged the battery up then tried starting it out of the water and it would turn over but sounded sluggish. So i set the mix on the carbs and not it will start and run out of water with a garden hose of course. But everytime i take it to the lake it will not start once in the water. It tries and will start but won't throttle up or idle. But once I take it out of water it works fine.
Could this be a battery issue...i.e. not enough amps to crank everything and the pump or whatever that sucks water in?
One of the cylinders has low compression would this be the cause? Not sure what to do and would really appreciate some input.
Thanks.
Thanks.
