SabrToothSqrl
pulled my ski's out of the water last friday, after running a few hours. everything normal.
I went to 'blip' the engine to blow water out of the exhaust.
engine went right up to 7,000 RPM SCREAMING, I couldn't kill it! stop/start didn't work, fuel valve shut off, pulled the plug wires! I dumped water on the top of the engine to try to keep it from melting!
Finally got it killed w/the choke.
what happened?!
I removed the airbox, and my friend and i tightend the screws on the carbs,tested compression (good)
this is after a rebuild last year
now it appears to work correctly, and idles at 3500 RPM on trailer, approx 1200-1400 in water.
anyway, runaway engine with the plug wires removed is NOT fun.
thankfully it didn't happen ON the water. i'd have been F*CKED.
what happened?!
