Ok, some of you (especially Dr. Honda and wabbit1211) have been following a thread to diagnose my engine issues. (Thanks a TON btw.....) I've now pulled the engine all the way out and have spent some quality time with it.
I took the head off while still in the boat and watched the tops of the pistons move. Not much to be seen there. Now that I've gotten it out, I took the intake assembly off as one big sub-assembly. I've now been manually cranking the FW and watching through the intake holes.
And it's not good news. One of the pistons appears to have separated. The head is moving from above, but when looking through the intake hole, the skirt is stationary and I'm assuming galled in the bore. So I suppose that there's a possibility that the conn rod is still good, but I'm not sure at this point.
So here's my question. Should I assume that I *may* be able to get away with a top end kit and disassemble from the top side? Or should I give in and just tear into it from the bottom?
I guess I'm kinda hoping that I could get away with a top end kit and leave the crankcase in one piece. Anyone think this is a bad assumption or should I just
proceed with a top side tear down and see what happens?
