benstoker
Hey everyone. I recently bought a 94 gtx fixer upper and have just pulled the engine on it. When I removed the carbs and rotary valve case, I noticed a chunk was missing from the rotary valve. The case looks fine (no grooves or anything) but the crankcase side is all sorts of grooved. From what I've read on here so far, if the rotary case has grooves/gouges from port to port, its no bueno and needs to be replaced or welded and resurfaced. Does the same true for the crankcase side? Whatever caused it is still in the case because I cant turn the motor over manually without a fight. Any insight you all might have would be greatly appreciated. I'm adding pics so you all can see what I'm looking at.
