SurfBeat
After exchanging my crankshaft and thinking I did everything right, when I dropped the engine in the hull yesterday, it would not start. (crank/yes - start/no)
Even though I am only a Shade Tree mechanic, and an incompetent one at that, since I had spark I knew it had to be a fuel flow problem when I noticed no fuel flowing to the filter bowl.
I checked my fuel selector and lines. All were fine.
Next I pulled the Impulse line from the carb to the engine and noticed no suction, but a tad of exhaust.
When I noticed an oil leak, that gave me the excuse to double check the way I aligned the RV, so rather than breaking my knuckles trying to get to the oil lines, I quickly jerry rigged a pulley and had the engine of of the hull in less than 45 minutes. Aplaud!!!!
I removed the Rotary cover, dropped a pen in the MAG cylinder port and quickly noticed what I did when I aligned the RV last week: I aligned it with the PTO cylinder TDC, rather than the MAG port. (I must have had the engine turned around and did not pay attention to detail.
To be sure I do the alignment right, I am enclosing a couple photos to show the exact postion where I aligned the RV: 130 BTDC/65ATDC.
I find the instructions confusing because after making the requisite marks, it is impossible to put the top edge of the RV at the 130BTDC and the bottom at 65ATDC.
So hopefully, the photos will provide an example of exactly where I now placed the RV after opening to TDC on the MAG cylinder porthole and aligning @ 130BTDC and 65 @ ATDC.
It is 4:00 p.m. here in CA, so, hopefully someone will let me know before the sun goes down whether I did the alignment correctly this time.
