ride plate repair
Redrover
Hi guys. I have a 2002 gtx that i believe is leaking at the fitting on the ride plate. How does everyone go about fixing the leaks at the plastic fittings?
I watched the vids on removal and replacement of the plate but haven't seen the fix. Thanks in advance for any info you might have.
If it is leaking it is probably corroded all to hell....pull it out and check it out...If it is still useable, JB weld or comparable sealant will permanantly seal the threads up if you do it right...Its a one shot deal...You wont get it apart again !
