twinpartners
Needed to be towed last night because my 2004 Sportster 4-Tec would not start. When I hit the start button it would just click-click-click. First thought was 1. Battery, 2. Wiring issue, 3. Solenoid, 4. Starter. It was night and we had been in shallow water fishing. I'd stop and we'd listen to some radio and had the fish finder and boat lights on. Every hour or so I'd hit the start switch so I wouldn't drain the battery. Was pretty sure that wasn't it. After the tow, went home and left the battery charger on all night.
This morning, it still wouldn't crank...just tap-tap-tap.
After checking the wiring and by-passing the solenoid, all I got was still a tap-tap-tap. So, it was a bad starter...right?
Hold on...decided to go ahead and pull all the plugs. Turned it over and the starter moved the crank just fine. NOW I was getting worried, but thought it could still be the starter because it wasn't under any load (piston compression)...right?
Hold on...went ahead and did a compression check while I was at it: perfect compression on all cylinders. So, I put all spark plugs back. Hit the start button and it FIRED RIGHT UP!! Did it twice...three times...no problems at all anymore.
Is there such a thing as "Vapor Lock"? It seems when I relieved the pressure on the cylinders by removing the spark plugs, my starter now has no problem firing the engine up. Any ideas???
