Revving out of control on trailer
jmikell6
I have a new problem, today I replaced a few fuel lines and set the carbs back to were they should be, I have a new motor with two tanks of gas through it. When I tried to start it on the trailer after putting new fuel lines on it revs up and I have to shut it off immediatley?? What's going on now
carbs need adjustment
K I'm an idiot, for those new to seadoos, when feeling for the low speed screws I guess I accidently turned the idle screw the whole way in and backed it out a turn, whoops they all felt the same, problem solved
Easy mistake. Low speed and throttle adjustments are in the same area and feel the same when you blindly stick your hand down there.
Just as a FYI.. We had trouble on our one machine when the intake came loose.. Wow, better hang on to that thing when it fires up in the lake. Couldnt figure out the issue, so give it some primer and with all that air it was like starting it WOT!
