kirkland
Thanks is advance!! Bottom line to simplify it...I heard air leak will cause this I shouldn't have any of those that I know of... I checked the carbs, looked inside with a mirror and there closed like they should be at idle...even after I cut the gas off and let it run out I tried to start it wondering where all this energy is coming from and still it runs and tries to go wide open every time, tries to keep running after you pull the key and try to stop it for a few seconds!!! I can't keep doing because it's not the way I wanted to break in my engine and when the throttle is not wide open but the engine is well you know idle oil from the oil pump but engine going crazy is very bad!:ack:
I started it up on the trailer with plenty of oil in the gas put a little in the plug holes and the injection for extra on the first start...well it starting revving out of control after it finnally started, I think too much oil kept it from sparking and flooded the crankcase with fuel.
Question, can that cause a run away like that, burning the fuel because after a few tries I couldn't keep letting my new engine do this I got an $80 gallon of 2 stroke break in oil and was going to break it in very well, now it's running out of control wont idle I have rebuilt the carbs and I installed the engine after I got it rebuilt all new gaskets done right. Before I got water in the engine from a head gasket I rebuilt the carbs and it was running awesome idling good and everything.
This is the first time I started it so I am not sure if it's the flooded crankcase if that can even make that happen...or if it has to do with all the work done by the guys that rebuilt it or me installing it.
