I'm trying to replace the wear bearing and am having trouble installing the O-Ring on the Ring Seal Carrier on the shaft. It all has to be installed with the shaft nearly put back in the flywheel. The O-Ring holds the Ring Seal Carrier in place. It seems impossible to place the O-Ring in the slot. Does this require a special tool or is there a special way to do this that I'm just not aware of?
Thanks
Thanks
