KyleW2
New oil tank grommets just came in for the SP. Since the oil tank is near full (3/4 or so), I'm thinking about clamping off the oil lines and pulling the tank out to drain it easier with minimal spillage (I am replacing the RV bath line also, so I'm prepared to spill a little out of there when I pull the line). I assume this would also make it easier to put the new grommets in.
Is this necessary or is there a simpler way to do it?
Also, how often should the 3/32nd lines be replaced? What about the oil filter? Both were replaced within the past 2 years (can't remember for sure if the oil lines were last summer or the year before).
Thanks!
Thanks!
