Ok im going to be replaceing my crank shaft in a200 gtx and i got the new crank shaft and it did not come with the outer oil seals do i needthem or not thanks
The bottom half of your engine needs to be air tight. if there is an air leak... at minimum, you will have a hard time tuning... and in the worst case... you will run lean and burn the pistons.
