I bought a 2001 Seadoo Sportster LE after checking the compression and reading 150. Took it out on the water and it fired it up right away and she ran really well for about 1/2 hour. Increased the throttle and hit some small waves, it immediately slowed down to a stall. Tried to start it and it would turn over, I would get it going and then die again. Finally got it up to idle speed and got it back to the launch. Out of the water I turned it on, fired up and no problem. I have been tinkering around with it in and out of the water and it seems as soon as it is in the water and it takes on the load of the water, it dies. I remember having the same problem with my 96 xp and through some research, read that it is was rectifier issue. Bought a rectifier installed it and ran like a champ! Never had the problem again
So I thought that I should try to replace the rectifier in my 2001 Speedster LE. I need help as to the location to replace it. I bought a new aftermarket Rectifier and I can't find anything online to help.
Please help
Please help
