Reeds on 951
92rslt1
So I discovered my 951 has some carbon fiber reeds. The tip of one looks pretty nasty so I wanted to replace them.
The problem is most reeds I find are 4 pedal. These are two pedal.
Does anyone know where I can find 2 pedal carbon reeds for a 951?
I think they are called V-force. The mother company is Motto Tasinari. That should give you a couple more key words to google.
Thanks!
After looking around for the v force, I found they are carbon tech reeds.
I also found a lot more things out that I didn't know about my ski.
In doing so I found out its ported, has a larger intake grate and a stainless prop that I think might be after market. The mpem also has something written on it in marker that has almost worn off, I'm thinking it might be reflashed or used.
So I have a few questions.
Do I go with High tension reeds or mid?
It has a rossier pipe, clamp on filters, maybe aftermarket impeller, large grate, , carbon reeds and some porting, maybe mpem flash, I wont know for sure until I see where the rev limit is. I'm thinking play it safe with mid tension?
Did the 951 come with stainless impellers stock?
