2000 seadoo gtx not running full speed
Tanman054
So I have made it to the end of the line with this 2000 seadoo gtx 951 carb model I need help I’m having issues with it getting to high rpm it will run great at 3500 rpm but won’t go over about 10 mile an hour I got a new pump and put it on along with new drive shaft and carbon seal kit as I thought cavitation was the issue on it then it still happened so I rebuilt the carbs and still having the same problem finally replaced the spark plugs over the weekend and clipped the plug wires a 1/4 inch back but no change got it out of the water and pulled the plugs to realize the pto cylinder not firing so checked for spark and had great spark on both cylinders came to realize it’s not getting fuel to the cylinder but getting fuel to both carbs can anyone help me please!
Could be fuel starvation
Could be poor compression
Is it charging
Could be plugs
Load test the battery
