R Ryno91 New Member Sep 11, 2021 #1 2014 gtx 155. Keep says reading key. I take the key out and put it back in and it says normal key any insight?
skiasylum Well-Known Member Sep 11, 2021 #2 If your only getting one beep, the ECM can’t find the key. Make sure your key is positioned on the post correctly. Mine will do the same thing if the key is slanted too far down. You need to hear two beeps before it will start.
ski-d00 Well-Known Member Sep 12, 2021 #3 Press the start button first and wake up the ECU, then put the key on. That is procedure outlined in the manual.
