rave valve ???
redbaron
Hi guys
This is my first 787 engine
Gtx 96
Today I remove the rave valves to cleaning
and I found that the guillotines was broken
or someone cut it
What it is the function of this valve ???
The engine turn freely
Here is a cut and paste I have had for some time, don't remember where I got it off hand. And here is a link from our sire on how to service them.
http://www.seadooforum.com/showthread.php?37588-How-to-service-Rave-Valve-Pictorial
They are a new breed of valve that attributes more power to these bigger engines.
The RAVE, (Rotax Adjustable Variable Exhaust) valves are located above the exhaust valve. There are 2 of them per engine. They are round with a red adjustment screw in the middle. It has a clip that holds it together. How they work is that they open the exhaust port larger as the engine rpm's increase. When the rpm's drop down so do the RAVE valves. They work on the principle of the pressure of the exhaust system. Rpm's increase, pressure increases and the valve opens, rpm's drop pressure drops, Valve closes. They should be de-carbonized annual. To disassemble the rave valves, remove the spring clip on top, remove the black cover. There is a spring under the cover. Remove the piston by turning it with a metric socket. On the bottom of the piston is the rubber "Bellows" be careful with the small retaining spring that hold the bellows on the piston. Remove the 2 Allen screws that hold the base on the cylinder. Remove the base and gasket. The long valve won't fall in the cylinder just pull it out. There is an o ring under the base, on the shaft of the guillotine valve. Be careful to see how it came apart as it has to go back together that same way again. On the base, notice the notch that it is facing down. Clean all the carbon off the guillotine valve. I use carb cleaner and 400 grit paper. A large wire wheel also works real well. Check the bellows for any small pin holes. If so replace it. If not, reassemble it on the clean guillotine valve, and install it back on the engine the same way it came apart. The guillotine valve only fits one way. The one closest to the exhaust pipe will come off differently then the other one. You will have to remove the Allen screws and turn the base so it clears the exhaust pipe. I would do one at a time in case you forget how it goes back together again. This way you can look at the other one and copy it. Do both engines 2 per engine. Take your time and if you have questions give us a shout. We'll be here to help you out.
A loose fit is necessary and normal though. The valves get very hot and expand, so loose clearances are necessary. But if the shafts have any wear on them, or the holes in the housings are getting oval shaped, you need to replace them.
The water regulator (WR), It will change the timing of when water gets injected into the pipe, which changes the performance a bit. It will not make your boat faster, but is an aid to the acceleration curve. Typically, the WR red cap is the opposite of where the RAVE caps are set. So, if the raves are adjusted outward, the WR cap in adjusted inward or vise versa. Adjusting the WR spring tension valve will either just delay or speed up when the valve opens.
If the RAVE valves are dirty it will not rev up correctly and could be causing your problem. On 787 engines the red adjuster knob should be flush with the top of the cover, for 951 engines it should be fully tightened in the cover bore.
The Water Regulator adjustment knob (the red cap) should either be screwed all the way in or flush to the top of the black ring of the cap. This will only affect performance, as far as how it jumps out of the hole or how well it runs for extended periods at WOT. Normally need to have an annual cleaning to keep them in top
condition. Its a ten minute job, But take your time, one at a time.
