Shawndeyeguy
So I have found two springs in the bottom of my used 1997 GTX . One looks just like the Rave spring and the other is a little more heavy duty. I found NO spring in my Water Control Valve, so popped the one that looked like RAVE valve spring in there. I now see there are two different part numbers for the springs and without them in hand I can't compare them. So do you think I should have the heavier spring in the water control valve, or the similar or same as rave valve spring or neither?
Thank You
Thank You
