800's work off crank case pressure ,stock 951's work off a solenoid you cant wait for something to break then fix it and blame it on the parts ....its called maintenance .....you might want to check your injection oil s**tty oil will create issues .....and carb parts don't where out (small replaceable parts yes) complete carb no and if your gona tune your bog will your Rave's good luck you probably have a fuel delivery issue (maybe lines clogging) that is causing a bogg
