Gasngo
Ok I get the basics but a couple of fine points. I have a 03 GTI LE RFI and they need service for sure. The exhaust pipe is in the way of the front valve! I cant pull it out without hitting the underside of the pipe. The rear came out fine but gummy so cleaning needed. So here my experience so far. Bolts out rear bellows housing up and off. I dropped a 10 MM socket on the to of the bellows to unscrew the blade if you will and it was not particularly tight. I see there is a locator ear on the valve that positions the valve back to the housing but I bet you can still drop the housing a blade back in backwards maybe. My thoughts where to reference the vacuum line but again that cap spins 360 or does it. I still have the forward Cyl. valve in place so I have something to go by. Should I snug up the blade to the bellows or leave a it a turn loose. I believe the manual is on my PC so Ill be looking wanted some input. Also I would assume that the forward valve will need to be unscrewed from the bellows/housing to get the room to lift out the blade out surely you dont remove the exhaust pipe. One more! any reason you cant spin the bellows when its sprung down to the housing with a wrench or socket. Taking care of course everything seems to be soft and flexible and it requires no effort at all just the tension from the springs.
