WAJetboating
We filled two 30+ gallon trash cans with water, yielding ~500 pounds of movable ballast. We also had a topped-off fuel tank. We drove around at various speeds, shifting the weight around and videoing everything. Back at the house, we downloaded the videos so we could do side-by-side comparisons.
Interesting and unexpected results. A few highlights:
* Adding weight actually worsens the wake at a standard wakeboarding speed of 20MPH. It appears the heavier hull sort of "irons out" the wake at higher speeds.
* Moiving the weight around didn't seem to affect the 20MPH wake very much. It obviously affected how fast we planed out, but once planed there wasn't much difference.
* Adding weight definitely improves the possibilities for wake surfing. Shifting the weight rearward and to port, plus having two adults sit on the port gunwale, created a surprisingly nice green wave at about 12.5MPH on the speedometer. It was a bit short lengthwise but had plenty of height. I've read that adding ballast to the front of the boat tends to lengthen a surf wave, so that will be a followup experiment.
Not a lot more hard data yet, but the experiments continue!
