Good day,
Lots of assumptions here ............................
Sometimes we have to... but in this case, I think we nailed it.
I would purchase a 50 year old airplane with no issue .................
I would too. There has to be logs, and certifications along the way, with inspectors that (should) know what they are looking at since people's lives are on the line. The Mechanic is certified, and he gets paid regardless if he passes you or not. AND, he is fully liable if he rebuilds your engine, and it fails. (There's an investigation, and he can go to prison) But on that note... I did build a KR2 in the early 90's, and didn't understand that point, and had it 90% framed up. But I took it to the local EAA, and the next morning I had a set of logs. (LOL)
But, on a boat... if you have an engine fail 10 minutes after a retard mechaniK hands it back to you... he may not even return your call.
What does astound me is that you can't leave a BOAT in the water. The doesn't mean it will not be cared for or cleaned regularly.
Why? You bought a big jetski. Did you look over the manual before you bought it? Going back to your opening line.... You made the assumption.
The boat ramp here in Tobermory is just ridiculous, none of us want to launch it for the day and take it out every day. I've seen other Sea Doo jet boats in at the marina and would never have thought it would need such water protection. .................
OK... I get to use a line from my Mom....... "Just because everyone else is jumping of a bridge, doesn't mean it's a good idea." LOL. Same as with the "I've
SEEN other Seadoo boats in at the marina". There are a few Seadoo's that can be left in the water. All the Mercury powered Seadoo's are rated to be left in. But every one of the Rotax powered boats are not. Also... not wanting to take it in and out is just a personal preference. I have a bunch of marinas around me, and I often think it would be nice to just go to the boat (in a slip) and jump in, and use it on a moments notice, and not have to deal with the idiots at the ramp. But I like to be able to go to a bunch of different places, and it would be more work to go get my boat, over having it in my driveway.
Anyway... I'm not making this up... if you simply read the owner's manual... you will see that Seadoo says it's not rated to be left in the water. Some people get away with it... but most don't. Over the years, I've seen a bunch of posts here saying... "Went to the dock, and my boat was underwater". Like I already said... deck drainage heads to the bilge, and the carbon seal on the driveshaft leaks by design. (keeps it cool)
Does anyone know if the two drain plugs can be left dangling when towing long distances or will they eventually fall out (or can I just pull them out completely and leave them with the key so i don't forget to put it back in).
Regards,
Paul
As long as the plastic is in good shape... it's fine. Mine dangle all the time. I'm sure if I walk out to my boat now... I will see some puddles under the plugs. Even covered, water seems to get into the bilge.
I really wish I could tell you something different... but the fact is... some boats are meant to be left in, and some aren't. And as far as reliability... it's all dependent on the owner, and what YOU have done and verified. DO NOT EVER take a mechanic's word that something was done properly. Especially when they are trying to sell something.
