Hello All,
Last week at Powell one of my 1999 Seadoo GS's started hesitating at full throttle then would die down to idle speed. As long as you gave it half throttle it would run. I've read quite a few posts with similar problems so it sounds mostly like it's a gas problem with either a dirty carb/needles, maybe ?raves(i don't know what this is) or rectifier, or maybe a filter on the side of the carb? The jetski has been left for repair but I'd like to have some education base when the mechanic calls.
Also always heard that the fuel lines in the Seadoos are garbage so what should I replace them with? I'd need the diameter size to pick up and about how much. Are they hard to replace? Hate to cause a gas spill at the lake!
Thanks so much for any advice,
Scott
Scott
