Well, almost there. My 1999 Challenger is getting there. Runnin better every weekend.
But I noticed am oil leak on one of the pumps and decided to take it out and fix it. TO my dismay, I was cleaning the oil and noticed small metal parts so I will take it apart for a rebuild.
The questions I have are:
1.- The impeller is very tight and wont unscrew. I am a little concerned about applying heat to something mounted on plastic but it seems that that is what is done. Is the heat applied to the outside of the impeller's hub or do you apply it only to the hole where the splines are?
2.- Do I need the impeller shaft locking tool shown on the manuals or is it safe to just hold the shaft in a vice (seems that this is what people do).
3.- Any tips on removing old bearings and seal, installing new ones? I may not have access to a press but will light careful tapping work? Do I need to get or machine a bearing seal install tool for this job? I may end up doing this anyway since I have access to a machine shop but just wondering.
Thanks,
Chris
Thanks,
Chris
