I have a 1997 GTX that is having issues with getting up to speed. If you try to give it a lot of throttle from a stand still then the rpms just shoot up and you barely move. It is similar to a car slipping the clutch or burning out, lots of rpms with barely any movement. Less throttle will slowly get it up to speed and seems to still reach full speed (eventually). It has been like this since the day I bought it (used in 2005) but thought it was the way the ski ran. We have started to tube more and the ski really struggles to get up to speed. Could this be solved by replacing the wear ring?(I have put atleast 50 hours on the ski this year alone)
Also, can someone please explain how a pto works on these skis, could it be the problem as well? Is the pto just an adapter that connects the engine to the drive shaft directly or is it more like a clutch?
Thank you
Thank you
