Just had block plate installed on my 2001 RX and have been told several different oil gas ratio mixtures. What is the proper mix? 40:1....50:1...Thanks!
Oil tank has been replaced twice and now the connection for the oil line was broken, that now needed replacement so my mechanic recommended using the block plate and go pre-mix. I have had a lot of issues with the oil lines and the tank the past several years.
40:1 is a good safe call IMO, but you'll use almost 2x more oil than with the injection system.
And I'd have a hard time using that premixed fuel in anything beside a lawnmower if you decide it's gotten too stale, burning that mix in a car is good way to clog the cat converter.
Thanks for the response. Not looking forward to mixing but am tired of issues with tank , lines and now the injector unit. Will give it a try for a season and see how it goes.
40:1 seems to be the answer.
No, 951's do not have a rotary valve or any oil needed in the cases like all the smaller seadoo's. The tank and lines can be completely removed if the oil pump is removed.
