Traveler101
I have 2013 GTI SE130 w/ Solas Concord SR-10/18A prop that appeares to have a stripped shaft and or prop thread. I removed the jet pump assembly and prop remained on the drive shaft spline. When I attempted to tighten the prop onto the jet pump shaft with splined bolt tool it doesn’t tighten up, i.e threads stripped.
Questions:
1. Is this a common issue?
2. What is the prop/shaft thread size (English or metric)
3. Can this be a spun Prop? Doesn’t appear to have a Prop bushing
4. How do you remove the prop shaft nut on opposite end when prop thread is stripped.
I’m new to forum and hope this is correct area to pos. It’s Grandson’s Sea Doo and I’m learning to how to repair. Need HELP!
Questions:
