I just inherited a SeeDoo. A 1998 GSX Limited. Never owned a PWC before.
I am having a problem getting it to run AND I ended up with water in the crank case and cylinders today.
So, if you can bear with the monologue, I know the bike sat for at least two years. The outside is sun baked but the motor looks really clean.
I drained out as much of the crappy brwon fuel as I could, poured in a couple gallons of fresh, drained that and poured in 4 more gallons of fresh.
It cranked up right away but then began to quit.
I was only able to get the rear cylinder to run and only by chokingit with my hand over the carb.
I finally got it to run on its own (not sure if it was both cylinders). I kept it running for a while but then it quit as soon as I gave it some gas.
I was distracted for about 15 minutes and went back to start it and found it hydrolocked. I took out the plugs and spun it and found there was water in both cylinders and in the crank. It took forever to get it all out.
I got it to run again but not on its own.
So, why did it hydrolock? Could it be because I left the flush system on for about 10 minutes while the engine was not running?
I checked compression. It is 90lbs in each cylinder.
Other Issues:
Start button does not work if I press it all the way in. Must only push it like 1/2 way.
Fuel selector (off, on, reserve) seems a little funcky. Could that be the fuel problem?
I know this is a lot. All help will be appreciated.
Bodi
Other Issues:
Bodi
