I have a 1998 Speedster - both engines start easily, boat accelerates and runs strong.
I have started to have a interment problem with one engine - when
I push the throttle hard forward - it will bog and not kick into max power.
It may run fine for a few hours - then the next time - I bring it out - problem
surfaces - If I run it full throttle it will stutter as it bogs, kicks in bogs kicks in.
I think it maybe a RAVE value problem - but that engine also has a very loose temperature sensor that the fitting broke - so it can wiggle loose -
I think the temerature sensor only controls the warning for engine heat?
Any ideas - of what the issue maybe??
Thanks in advance.
Thanks in advance.
