premix ratio after rebuild
if your oil injection is still hooked up.... add enough oil to mix your fuel at 50:1. Over all (with the injection) your engine will be running at ~32:1. After the first tank, and after you verify the oil injection is working, run regular fuel.
If you are only pre-mix (no injection) run your first tank at 32:1, and then 40:1 after that.
i just rebuilt my engine too
i'm going to pull the cam on the oil pump wide open and wait 30+ sec to see if the boat starts smoking a lot thicker
that
that's a good idea, that will verify that mine is pumping oil!
thanks! (i had to pull mine when I replaced the stator).
