Roostdaddy
I have searched and talked to the guys at PWCMuscle and still haven’t tracked down the culprit.
2012 Wake Pro 215 run in sport mode and lacks performance, only revs to near 6000rpm range unless you unload the motor and then it will keep the rpm up to the 8000 mark until you back off the throttle. Then the issue reoccurs.
Rebuilt sc, checked hoses for leaks, fresh oil on the marks, second set of plugs and fresh gas
