Please assist - Not sure where to post - Seadoo repair question
Tara649
I am assisting my uncle in the repair of a 1997 GTS Seadoo that appears to have 717 engine based on the manual. We would like to request a picture of the engine and cooling system to assist in the repair and proper reinstallation of the cooling hoses and wiring. If anyone has one of these machines and can assist we would appreciate it. We are trying to replace the water inlet hose (?) and need some guidance on location. Thanks in advance!
On the top of the cylinder at each fitting there should be an arrow indicating inlet and outlet,,,the inlet cooling hose from the pump is essy to find,,,it will be beside the 2 bilge tubes at the top of the pump.
Thank you for replying. We are actual king trying to figure out the correct placement of the black tube pictured below with the clamp attached as the blue wire seems to be crimping it when installed. Any suggestions are appreciated 2D6D7CC4-5396-4E72-97A1-DB333040B124.jpeg
