Hi everyone,
I purchased a Seadoo GTX Bombardier limited 951 model year 1999. My son and I took it out and went very well, but then after 15 minutes 12v low started flashing. I changed the battery and the issue still remained, where you would be going along and when you increased speed it would cut out and again the low 12v would be on the dash. I have now changed the fuses in the mpem and one in the electrical box, again still the same message. With engine off battery reads 12.48, then with engine running reads 12.38, so there is no charge going into the battery to make it stable. I have taken the mpem out and is like to test it, but I'm not sure how I do it? Ideally I need to test it before I purchase a new one as there very expensive. Is there a way to test them? Also if I can test it and it's fine, what do I do next? Thanking you in advanced
