It was pretty tight could see light around the impeller 1/16th to 1/8th inch consistent all the way around.... also i'm assuming the wear ring would be my cavitation issue
Yes, if it was cavitation it is the wear ring...The ring wears out so you don't have to replace the expensive impeller all the time. The impeller dosen't look bad at all.
